israelfdzhdz_34's avatar
israelfdzhdz_34
Mar 01, 2019
How create Health Monitor https.
The F5 has a load balancing of two nodes in the HA scheme. (Node A - Active PRD // Node B - Passive Standby) and when I run the command curl -I -k https:///mifs/login.jsp (each node), the answer is the follow:
Nodo A respond with HTTP/1.1 200 OK Server: serverevalidate Content-Type: text/html;charset=UTF-8
Nodo B respond with HTTP/1.1 503 Service Unavailable Server: server Content-Type: text/html; charset=iso-8859-1
It's possible create a monitor, when the node A response is HTTP/1.1 200 OK the node is UP and the node B respond is HTTP/1.1 503 Service Unavailable this node is DOWN.
  • Hi,
    If you want Node A to serve traffic (active) and only want Node B (standby) to serve traffic if Node A goes down, you can use a feature called priority group activation
    1) Create an HTTPS health monitor
    tmsh create ltm monitor https MONITOR-HTTPS-LOGIN defaults-from https send "GET /login.jsp HTTP/1.1\r\nHost: mifs\r\nConnection: close\r\n\r\n" recv "200 OK"
    2) Apply HTTPS health monitor to pool and enable priority group activation
    tmsh modify ltm pool  monitor MONITOR-HTTPS-LOGIN members modify { : { priority-group 10 } : {priority-group 5 } } min-active-members 1
