WildWeasel's avatar
Jun 08, 2016
How could I use iRule and Data Group vs Query Logging on External GTM's
We have an environment where we have an external view on our Infoblox Servers that sync with our External(public/internet facing) GTM's.
I have about 300+ domains that I need to validate are no longer being used and my old DNS days tells me to turn on query logging on my 4 External facing GTM's to capture any attempts on those GTM's for a min of 30days which would be over 1000+ domains then try and search for the 300+ domains I am trying to do research on. If this is the route, then I am going to try and utilize Splunk for the parsing of the data but a few issues with this approach is I'm not sure our Splunk Server(s) have the capacity for a month worth of queries on 1000+ domains and another issue is the GTM's are already highly utilized in Memory and CPU and adding query logging I'm afraid will kill them.
A better option I believe would be to utilize an iRule and a Data Group but not quite sure how to assemble this solution.
My thought is to create a Data Group (DG) with either 300+ specific domains or hopefully I can use wildcards so instead of blah.com I could use (la.com) which would cover multiple that I want to capture data on.
Create an iRule to look at incoming DNS_REQUEST and change to all lower case (since everything seems so case sensative), see if the DNS_REQUEST contains a domain in the DG if so, then send to the log "domain blah.com is in use, record type is [DNS::rrtype]"
Anyone have any thoughts on this approach and what the iRule may look like?
