Hostname split
Hello
I need to split a hostname into three parts ( ..).
This can be done al least on two ways:
1) scan [HTTP::host] %\[^.\].%\[^.\].%s prefix host suffix
2) set prefix [getfield [HTTP::host] "." 1]
set host [getfield [HTTP::host] "." 2]
set suffix [getfield [HTTP::host] "." 3]
Both work, but the problem comes when there is no prefix ( f5.com instead of www.f5.com). In that case scan fails and the second method leaves suffix empy, assign .com to host and f5 to prefix
I've done this to solve this:
set longitud [ string length $suffix ]
if { $longitud < 1 } {
set host [string tolower $prefix ]
It works, but it doesn't look quite ellegant nor efficient.
Is there a better way to solve that particular case?
Thank you.
- nitass
Employee
this is mine but i think it is not efficient anyway. 🙂[root@ve10:Active] config b rule myrule list rule myrule { when RULE_INIT { set hostname "f5.com" set last_dot [string last "." $hostname] set second_dot [string last "." $hostname [expr {$last_dot -1}]] set suffix [string range $hostname [expr {$last_dot + 1}] end] set host [string range $hostname [expr {$second_dot + 1}] [expr {$last_dot - 1}]] set prefix [string range $hostname 0 [expr {$second_dot - 1}]] log local0. "hostname=$hostname | prefix=$prefix | host=$host | suffix=$suffix" set hostname "www.f5.com" set last_dot [string last "." $hostname] set second_dot [string last "." $hostname [expr {$last_dot -1}]] set suffix [string range $hostname [expr {$last_dot + 1}] end] set host [string range $hostname [expr {$second_dot + 1}] [expr {$last_dot - 1}]] set prefix [string range $hostname 0 [expr {$second_dot - 1}]] log local0. "hostname=$hostname | prefix=$prefix | host=$host | suffix=$suffix" set hostname "xxx.yyy.f5.com" set last_dot [string last "." $hostname] set second_dot [string last "." $hostname [expr {$last_dot -1}]] set suffix [string range $hostname [expr {$last_dot + 1}] end] set host [string range $hostname [expr {$second_dot + 1}] [expr {$last_dot - 1}]] set prefix [string range $hostname 0 [expr {$second_dot - 1}]] log local0. "hostname=$hostname | prefix=$prefix | host=$host | suffix=$suffix" } } [root@ve10:Active] config tail -f /var/log/ltm Oct 12 19:25:48 local/ve10 err mcpd[3815]: 01020066:3: The requested rule (myrule) already exists in partition Common. Oct 12 19:25:48 local/tmm info tmm[7926]: Rule myrule : hostname=f5.com | prefix= | host=f5 | suffix=com Oct 12 19:25:48 local/tmm info tmm[7926]: Rule myrule : hostname=www.f5.com | prefix=www | host=f5 | suffix=com Oct 12 19:25:48 local/tmm info tmm[7926]: Rule myrule : hostname=xxx.yyy.f5.com | prefix=xxx.yyy | host=f5 | suffix=com - soymanue
It looks better tan mine :-)
Thank you
- What_Lies_Bene1
I wouldn't know how to code it but assuming you know that the domain name or names will always end .com or whatever, why not just compare $host against .com and if it's a match, shuffle your fields: set suffix = $host, set host = $prefix, set prefix = "blank"?
- soymanue
We have several suffixes: .com, .org, .es, .biz, .eu, .int
- What_Lies_Bene1
You could do a compare against a Data Group to get around that. - soymanue
I don't how how does it work
Where can I find and example?
Thanks - Kevin_Stewart
Employee
I'd probably turn it into a list:set myhost [split [HTTP::host] "."]
Then you could use the full force of list commands for processing.
- llength to determine the size of the hostname
- the last index is the root: [expr [llength $mylist] - 1] - What_Lies_Bene1
Kevin's probably onto something there but if you did take the data group route, create and populate the data group and use code something like this;if { [class match [string tolower $host] contains suffix_data_group ] } { 'do something here' } - nitass
Employee
i like Kevin's idea.[root@ve10:Active] config b rule myrule list rule myrule { when RULE_INIT { set hostname "f5.com" set lhostname [split $hostname "."] set suffix [lindex $lhostname [expr {[llength $lhostname] - 1}]] set host [lindex $lhostname [expr {[llength $lhostname] - 2}]] set prefix [lindex $lhostname [expr {[llength $lhostname] - 3}]] for {set i [expr {[llength $lhostname] - 4}]} {$i >= 0} {incr i -1} { set prefix "[lindex $lhostname $i].$prefix" } log local0. "hostname=$hostname | prefix=$prefix | host=$host | suffix=$suffix" set hostname "www.f5.com" set lhostname [split $hostname "."] set suffix [lindex $lhostname [expr {[llength $lhostname] - 1}]] set host [lindex $lhostname [expr {[llength $lhostname] - 2}]] set prefix [lindex $lhostname [expr {[llength $lhostname] - 3}]] for {set i [expr {[llength $lhostname] - 4}]} {$i >= 0} {incr i -1} { set prefix "[lindex $lhostname $i].$prefix" } log local0. "hostname=$hostname | prefix=$prefix | host=$host | suffix=$suffix" set hostname "xxx.yyy.f5.com" set lhostname [split $hostname "."] set suffix [lindex $lhostname [expr {[llength $lhostname] - 1}]] set host [lindex $lhostname [expr {[llength $lhostname] - 2}]] set prefix [lindex $lhostname [expr {[llength $lhostname] - 3}]] for {set i [expr {[llength $lhostname] - 4}]} {$i >= 0} {incr i -1} { set prefix "[lindex $lhostname $i].$prefix" } log local0. "hostname=$hostname | prefix=$prefix | host=$host | suffix=$suffix" } } [root@ve10:Active] config tail -f /var/log/ltm Oct 12 19:58:52 local/ve10 err mcpd[3815]: 01020066:3: The requested rule (myrule) already exists in partition Common. Oct 12 19:58:52 local/tmm info tmm[7926]: Rule myrule : hostname=f5.com | prefix= | host=f5 | suffix=com Oct 12 19:58:52 local/tmm info tmm[7926]: Rule myrule : hostname=www.f5.com | prefix=www | host=f5 | suffix=com Oct 12 19:58:52 local/tmm info tmm[7926]: Rule myrule : hostname=xxx.yyy.f5.com | prefix=xxx.yyy | host=f5 | suffix=com
