Hight Avilability on tcp/ip level using f5 product
Hi we are the company that selling application to our customers
i'm currently trying to identify if we can use your product to organise a HA on tcp/ip level but didn't find any documentation saying that this possible
can you help me out with that ? typical usage for us is when a lot of devices need to connect to some service and we want to make this service always rechable and balance load between backends that provide this service on some specific port
- nitass_89166
Noctilucent
have you checked about local traffic manager (ltm) module?
- gitler_162652
yes i did but in datasheet information about this is not very clear features: "· Application protocol support (TCP, HTTP, SPDY, SSL, SIP, FIX, MS SQL, etc.)" it saying like it supporting some specific application or services.
- nitass
Employee
- gitler_162652
- nitass
Employee
tcp is supported.
you may try trial edition.
F5 Free Trial
https://www.f5.com/trial/big-ip-ltm-virtual-edition.php - Kevin_Stewart
Employee
If I may add, the BIG-IP is a network proxy device. Like a router or a switch, it plugs into TCP/IP networks, but unlike a switch or router is highly intelligent at OSI layers 4 through 7. The protocols that you mention are simply the ones that BIG-IP is "smarter" about than others. It is agnostic to any other protocols and can handle any TCP or UDP traffic.
- Mahmoud_Eldeeb_
it supports TCP, however it is not functioning well with voice or video traffic
- Kevin_Stewart
Employee
I don't believe that's true. BIG-IPs are used in major telcoms for SIP and other audio/video traffic.
