Pieter_72260
Feb 07, 2013High speed logging and round robin load balancing issues
We have a couple of F5 servers that have an iRule that uses HSL to send log messages to a pool of remote rsyslog daemons.
The rsyslog daemons are added to one pool, and the pool is con...
nitass
Employee
Mar 20, 2013what about this one?
[root@ve10:Active] config b virtual bar list
virtual bar {
snat automap
pool foo
destination 172.28.19.252:80
ip protocol 6
rules myrule
profiles {
http {}
tcp {}
[root@ve10:Active] config b rule myrule list
rule myrule {
when RULE_INIT {
set static::i 0
when CLIENT_ACCEPTED {
if { $static::i == 0 } {
set loghost loghostp1
set static::i 1
set loghost loghostp2
set static::i 0
set hsl [HSL::open -proto TCP -pool $loghost]
set host [HTTP::host]
set uri [HTTP::uri]
when HTTP_RESPONSE {
HSL::send $hsl "<190> [IP::client_addr]:[TCP::client_port] $host $uri\n"
[root@ve10:Active] config b pool loghostp1 list
pool loghostp1 {
members 200.200.200.101:514 {}
[root@ve10:Active] config b pool loghostp2 list
pool loghostp2 {
members 200.200.200.111:514 {}
send 500 requests to virtual server
[root@centos251 ~] ab -n 500 http://172.28.19.252/
This is ApacheBench, Version 2.0.40-dev <$Revision: 1.146 $> apache-2.0
Copyright 1996 Adam Twiss, Zeus Technology Ltd, http://www.zeustech.net/
Copyright 2006 The Apache Software Foundation, http://www.apache.org/
Benchmarking 172.28.19.252 (be patient)
Completed 100 requests
Completed 200 requests
Completed 300 requests
Completed 400 requests
Finished 500 requests
Server Software: Apache/2.2.3
Server Hostname: 172.28.19.252
Server Port: 80
Document Path: /
Document Length: 89 bytes
Concurrency Level: 1
Time taken for tests: 2.145340 seconds
Complete requests: 500
Failed requests: 0
Write errors: 0
Total transferred: 175500 bytes
HTML transferred: 44500 bytes
Requests per second: 233.06 [/sec] (mean)
Time per request: 4.291 [ms] (mean)
Time per request: 4.291 [ms] (mean, across all concurrent requests)
Transfer rate: 79.71 [Kbytes/sec] received
Connection Times (ms)
min mean[+/-sd] median max
Connect: 0 0 0.6 0 3
Processing: 2 3 1.2 3 14
Waiting: 2 2 1.3 3 13
Total: 3 3 1.3 3 14
Percentage of the requests served within a certain time (ms)
50% 3
66% 4
75% 4
80% 4
90% 4
95% 5
98% 8
99% 10
100% 14 (longest request)
pool stats
[root@ve10:Active] config b pool loghostp1|grep -i request
| requests (total) = 250
[root@ve10:Active] config b pool loghostp2|grep -i request
