Pieter_72260
Feb 07, 2013High speed logging and round robin load balancing issues
We have a couple of F5 servers that have an iRule that uses HSL to send log messages to a pool of remote rsyslog daemons.
The rsyslog daemons are added to one pool, and the pool is con...
Pieter_72260
Feb 13, 2013Hi nitass,
I was partially able to get it working using UDP.
It works fine I just manually launch requests using a browser.
But the moment we create a higher load (60qps) using multiple threads the load balancing stops.
Everything is going to one server again.
And this morning it seems to have worked in one of our DC's with TCP after log rotation kicked in on the rsyslog daemons.
But the distribution ratio of the requests is not equal. one node gets 25% of requests and the other 75%.
Kind regards,
Pieter
