Zaklina_377109's avatar
Zaklina_377109
Feb 04, 2019
High availability problem when using virtual machines
Hello,
We do have problem with config synchronization between two cluster members. They are installed on KVM and cannot ping each other after synchronization of the config is enabled. Two machines are using trial licences. When I try to change state of the cluster member form active to standby, it works correctly. Do you have some similar issue or does the trial licences may cause some problems?
  • Nath's avatar
    Nath
    Do you have logs on both devices when you are trying to push config sync?
