Zaklina_377109
Feb 04, 2019High availability problem when using virtual machines
Hello,
We do have problem with config synchronization between two cluster members. They are installed on KVM and cannot ping each other after synchronization of the config is enabled.
Two machin...
Nath
Feb 05, 2019Do you have logs on both devices when you are trying to push config sync?
