szia_80879's avatar
szia_80879
Oct 17, 2007
Help with rewriting the URI
I am trying to create iRule(s) that would do the following:
- Users can come in on either port 80 or port 443. If a user comes in on port 80 they should be redirected to port 443. (It is done successfully.)
- After the request is redirected to port 443, access to a virtual pool should be based on IP address or IP range. If user has a registered IP address, the user should be redirected to
https://x.y.z:7008/int/intsearch. (A request to URI of / should be rewritten to /int/intsearch)
All other users should be directed to
https://x.y.z:7006/ext/extsearch (A request to URI of / should be rewritten to /ext/extsearch)
I have successfully created a trusted datagroup and an iRule that have redirected client’s request based on the IP address. However, I am having trouble rewriting the URI while it is redirecting the request. How do I add the URI rewrite feature while redirecting the request?
The Code is:
redirection_acl_rule
this event is triggered when a client - BIPIP TCP connection is established
when CLIENT_ACCEPTED {
is client IP address defined in the trusted datagroup?
if { [matchclass [IP::client_addr] equals $::trusted_datagroup] } {
pool Internal_7008_Pool
requests that did not match the conditions redirect to the External search
pool External_7006_Pool
log the client IP address -> destination IP address
log local0. "request accepted from client: \
[IP::client_addr] -> [IP::local_addr]"
Any help will be greatly appreciated.
Thank you.
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    Well, it looks like you're almost there. The only thing you need to add now is the logic around the HTTP::uri command to change the uri as desired. If you're looking to change all Internal pool request URIs to /int/intsearch and all external request URIs to /ext/extsearch, you'd want something like:
        HTTP::uri /int/intsearch
        HTTP::uri /ext/extsearch
    If you only wanted this done if they had no requested URI or a URI of "/", then you'd need some additional logic:
        if{ [string length [HTTP::uri] <= 1 } {
    HTH,
    Colin
  • Colin,
    Thank you for the codes. It did help me a lot. Initially, I had some additional problems; however, I was able to resolve them. It is working the way I wanted. I really appreciate the help.
    Thank you.
