eugenix_116516's avatar
eugenix_116516
May 08, 2013
Help with Port Translation
Apologies in advance if this is the wrong forum or place to ask this question, but I can't seem to figure this out.
We have a Java Web Server application (ManageEngine's AD Self Service) that uses port 9251. We would like to use our F5 to create a virtual server such that we can give our users a simple URL instead of
I created a new virtual server with a new IP and then created a pool with just the webserver in it, set it to use HTTPS and specified port 9251. I used the java keytool to export the server cert & key (from our internal Enterprise Root CA). I created an SSL Server profile, specified the cert & key, left everything else default. On the virtual server, I specified the SSL Server profile, and at the moment, am just leaving the Client profile as 'none', so they can it over port 80.
Do I need some kind of iRule to make this happen? Any tips, hints, help greatly appreciated.
Forget to mention, we have a BIG-IP 1600 , running 10.2.3
Thanks,
Eugene
