jgranieri
Jan 19, 2012Help with logic on header check irule
Hello All,
So i have an irule in which I need to check http header for mozilla then check the URI then LB appropriately. after this condition I have 2 other URI that are from a browser and need to be LB appropriately.
So If /aaa does not come from mozilla send to pool aaa, otherwise send to zzzz
/bbb and /ccc are browser based and need to go to the respective pools.
I know I have the default pool at the end but i need to somehow that with an else after the
"*/aaa*" { pool aaa }
{else}
pool zzz}
/bbb and /ccc are browser based and will contain mozilla in the header field
if { not [string tolower [HTTP::header Accept]] contains "Mozilla" } {
switch -glob [HTTP::host][HTTP::uri] {
"*/bbb*" { pool bbb }
"*/ccc*" { pool ccc }
default {
pool zzz }
- Chris_Phillips
OK, so you seem to be saying that /aaa is a special treatment compared to /bbb and /ccc? in which case, I think you're describing this:when HTTP_REQUEST { switch -glob [HTTP::uri] { "/aaa*" { if { not [string tolower [HTTP::header "User-Agent"]] contains "mozilla" } { pool aaa } else { pool zzz } } "/bbb*" { pool bbb } "/ccc*" { pool ccc } } }
Is that what you mean? You mention needing a default, yet your description doesn't seem to want one at all. Can you clarify?
So a few things I'd point out...
1) You're using [HTTP:host] and then completely ignoring it. Also introducing potential vagueness into the switch - your logic would match, host.com/ccc/aaa/blahblahblah as "/aaa", which is surely not what you want.
2) You're using the Accept header, when you surely mean the User-Agent header?
[EDIT: s/mozilla/Mozilla/ as per Hoolio's comment below ] - hoolio
Good points Chris. Also, if you're setting the User-Agent header to lowercase make sure the string you're comparing it with is lower case, like "mozilla".
Aaron - jgranieri
@ Chris - Yes I need /aaa to be lb based on header field detection I will try your changes.
@ Aaron thanks as well
I am going to try this to see if I can get this to work.
