jj24_43946
Jun 13, 2011Help with LocalLB::VirtualServer/Create
Hi again, I'm trying to create a VirtualServer, but I'm gettting the following error: SOAP-ENV:Server Could not find element by name: profile_context Here's my profile part of the datastructure:
$VAR1 = {
'profile_name' => 'test_pool_VS',
'profile_context' => 'PROFILE_CONTEXT_TYPE_ALL'
Did I build that correctly? Here's my perl code to build the data structure:
my $protocol_type = 'PROTOCOL_TCP';
my $VirtualServerDefinition =
name => "Sitename_VS",
address => '10.10.10.254',
port => 80,
protocol => $protocol_type
my $VirtualServerType = 'RESOURCE_TYPE_POOL';
my $VirtualServerResource =
type => $VirtualServerType,
default_pool_name => 'Sitecode_B2C_http'
my $ProfileContextType = 'PROFILE_CONTEXT_TYPE_ALL';
my $VirtualServerProfile =
profile_context => $ProfileContextType,
profile_name => 'Sitecode_prod_http_VS'
my $VSDefinition =
definitions => $VirtualServerDefinition,
wildmasks => '',
resources => $VirtualServerResource,
profiles => $VirtualServerProfile
Any idea why I'm getting the profile_context error?
Thanks !
- I'm not sure how you are passing the values into the actual create method so it's hard to predict what the exact problem is. Here's how I've done it in the past
sub createVirtual() { $VirtualServerDefinition = { name => "Sitename_VS", address => "10.10.10.254", port => "0", "80", protocol => "PROTOCOL_TCP" }; $wildmask = "255.255.255.255"; $VirtualServerResource = { type => "RESOURCE_TYPE_POOL", default_pool_name => "Sitecode_B2C_http" }; $VirtualServerProfile = { profile_context => "PROFILE_CONTEXT_TYPE_ALL", profile_name => "Sitecode_prod_http_VS" }; $soapResponse = $VirtualServer->create ( SOAP::Data->name(definitions => [$VirtualServerDefinition]), SOAP::Data->name(wildmasks => [$wildmask]), SOAP::Data->name(resources => [$VirtualServerResource]), SOAP::Data->name(profiles => [[$VirtualServerProfile]]) ); &checkResponse($soapResponse); print "Virtual Server Created!\n" }
Hope that helps...
-Joe - jj24_43946
It worked great. I thought I had done it the same, but looks like you have double brackets around the profile value for the soap submission. That must have been what did it. Thanks again!! - Anytime! I guess all those iControl samples I've written for the past 7 years are starting to pay off B-). BTW, the double brackets are to specify that that parameter is a 2-D array.
-Joe
