Meena_60179
May 05, 2010Help with JSESSIONID persistence
Hello,
I am using tomcat's JSESSIONID for persistence and I created iRule using this example http://devcentral.f5.com/wiki/default.aspx/iRules/Weblogic_JSessionID_Persistence.html
However I have couple of doubts here, I am not sure that whether I need to configure default persistence profile with the pool or not, if so how can I do that?
Second, when I reload the app with in sessiontimeout period BIG IP sends request to another server, so I want to know why reloading is breaking the persistence setting even though JSESSIONID is with the request.
Thanks for the help.
- Meena_60179
I also persist for some times and without me doing anything bigip deletes the entry in persistent table, and then next request is forwarded to different node (say 1.2). I am not deleting JSESSIONID, if I wait for sometime BIGIP again deletes persistence entry for 1.2 and recreates new entry for 1.1 after next request. I think 3600 should be the timeout for bigIP, which means an hour ??
Here is the configuration for my virtual server:VIRTUAL ADDRESS 17.184.8.110 UNIT 1 | ARP enable | (cur, max, limit, tot) = (0, 5, 0, 51) | (pkts,bits) in = (4912, 5.243M), out = (17229, 77.93M) +-> VIRTUAL vs_uie_appserver SERVICE http | PVA acceleration none | (cur, max, limit, tot) = (0, 5, 0, 51) | (pkts,bits) in = (4912, 5.243M), out = (17229, 77.93M) | requests (total) = 374 +-> POOL test_uie_pool LB METHOD round robin MIN/CUR ACTIVE MEMBERS 0/2 | (cur, max, limit, tot) = (0, 6, 0, 36) | (pkts,bits) in = (4710, 5.233M), out = (7086, 74.11M) +-> POOL MEMBER test_uie_pool/192.168.1.1:webcache active,up | | session enabled priority 0 ratio 1 | | (cur, max, limit, tot) = (0, 3, 0, 18) | | (pkts,bits) in = (2857, 3.278M), out = (4276, 44.76M) | | requests (total) = 237 +-> POOL MEMBER test_uie_pool/192.168.1.2:webcache active,up | session enabled priority 0 ratio 1 | (cur, max, limit, tot) = (0, 3, 0, 18) | (pkts,bits) in = (1853, 1.954M), out = (2810, 29.35M) | requests (total) = 137
