Jason_19901
Apr 07, 2011Help with iRule
here is my requirement:
This iRule will be applied to an already existing virtual service for payme.example.com
+ Deny all access to URI payme.example.com/nfm (and all subdirectories) from all IP sources
+ These following IP addresses (create datagroup) are allowed to URI payme.example.com/*.asmx
222.27.26.151, 222.27.26.152, 222.38.4.248, 222.27.16.165, 222.27.16.169
+ Deny all access to URI payme.example.com/*.asmx from all other IP sources
+ Allow all access to URI payme.example.com/ (and all remaining subdirectories) from all IP sources
This iRule will be applied to an already existing virtual service for upayme.example.com
+ Deny all access to URI upayme.example.com/nfm (and all subdirectories) from all IP sources
+ These following IP addresses (create datagroup) are allowed to URI upayme.example.com/*.asmx
222.27.26.148, 222.38.4.249, 222.27.16.158, 222.27.16.161
+ Deny all access to URI upayme.example.com/*.asmx from all other IP sources
+ Allow all access to URI upayme.example.com/ (and all remaining subdirectories) from all IP sources
Here is my iRule that does not seem to work
class UserDataGroup {
host 222.17.26.151
host 222.17.26.152
host 222.28.4.248
host 222.17.16.165
host 222.17.16.169
class UserData_Group {
host 222.17.26.148
host 222.28.4.249
host 222.17.16.158
host 222.17.16.161
when CLIENT_ACCEPTED {
set debug "1"
if {$debug} {log local0. "Client IP address is: [IP::remote_addr]"}
Check if client IP is not in the UserDataGroup
if { [matchclass [IP::remote_addr] equals $::UserDataGroup] }{
log local0. "Client is in UserDataGroup1"
Prevent the HTTP_REQUEST event from firing if user is from local network
event HTTP_REQUEST disable
else {log local0. "Client is in NOT UserDataGroup"}
switch -glob [HTTP::uri] {
"/*.asmx" -
"/nfm" -
Reject login info from non local sites
HTTP::respond 403 content "Logins only allowed from trusted networks.\r\n"
set debug "1"
Check if client IP is not in the UserData_Group
if { [matchclass [IP::remote_addr] equals $::UserData_Group] }{
log local0. "Client is in UserData_Group1"
else {log local0. "Client is in NOT UserData_Group"}
"/nfm" -
"/*.asmx -
- hoolio
Which version are you testing this on? Can you add debug logging to the iRule to see exactly what's not working? You can use the log command to do this and check the output in /var/log/ltm.
Aaron - Jason_19901
im using 10.2. not sure how to do that...new to iRules - JRahm
Admin
From your iRule, this is a debug log statement:
Since you have "set debug 1" above, this means that these lines will log to /var/log/ltm file. You can check for the info in your log (or any tcl errors) and any debug log statements that might help isolate where your problem is. Make sense?
