Help with iRule syntax
Hi members,
Need help with iRule programming. can someone help provide assistance to have this script work?
when HTTP_REQUEST { if { not ([class match [string [IP::local_addr] ]] contains ApiGWHosts]) }{ foreach header {idm_header} { HTTP::header remove $header } } }
It's giving out an error. PARSE syntax 93 {syntax error in expression " not ([class match [string [IP::local_addr] ]] contains ApiG...": variable references require preceding $}][{ not ([class match [string [IP::local_addr] ]] contains ApiGWHosts])
Thanks!! and appreciate the help!
- stan_piron
Cumulonimbus
you can try this version:
when HTTP_REQUEST { if { not ([class match [string [IP::local_addr] ] contains ApiGWHosts]) } { foreach header {idm_header} { HTTP::header remove $header } } }there was 1 closing bracket I removed and a space I added between
and}
at the end of if condition{ - stan_piron
Cumulonimbus
when HTTP_REQUEST { if { not ([class match [IP::local_addr] contains ApiGWHosts]) } { foreach header {idm_header} { HTTP::header remove $header } } }
