MikeBrockbank_3's avatar
MikeBrockbank_3
Apr 25, 2017
help with iRule and built in https_redirect working with it
I need to get this iRule to work,which it is not. But since it is on an HTTP cluster I also need to use the built-in sys_https_redirect to work AFTER this iRule takes effect. Can you help me with both of these problems? Here is the iRule.
when HTTP_REQUEST { switch [string tolower [HTTP::uri]] { "/reportal" { pool PROD_APPS5_JBOSS_8080_POOL }
  • What is functionality that you are looking to achieve ?
    Why is the iRule not working ? Are you seeing errors in the logs ?
    You can change the "eq" in the following iRule to "contains" or "starts_with" depending on your needs:
    if { [string tolower [HTTP::uri]] eq "/reportal" } {
