jasm_146487's avatar
jasm_146487
Mar 30, 2015
Help with iApp creation
I was wondering if anyone had complete examples of how to create a basic iApp using powershell and iControl?
I have scoured the forums, blogs, posts, tech article and there's absolutely nothing apart from examples in Perl. Although looking at these example does help I'm having issues creating the scalar_vars for the f5.microsoft.iis template.
So in psuedo terms I'm doing the following :
$scalar_vars = @(0..10) this is the only way I can get a 'list' of named pairs. Hastable of hashes wont work
  for ($i=0; $i -lt 10; $i++){
        $scalar_vars[$i]=New-Object iControl.ManagementApplicationServiceScalarVar
        $scalar_vars[$i].name = $iApp.scalar_vars[$i].name     pool__addr
        $scalar_vars[$i].value = $iApp.scalar_vars[$i].value   10.10.10.10
At the end I get an array of objects using the iControl.ManagementApplicationServiceScalarVar object
$scalar_vars
name                                                     value
pool__addr                                               10.10.10.10
pool__port                                               80
net__server_mode                                         lan
net__client_mode                                         lan
server_pools__create_new_pool                            test-HTTP
optimizations__lan_or_wan                                LAN
server_pools__create_new_monitor                         Use Monitor...
server_pools__reuse_monitor_name                         /Common/http
server_pools__lb_method_choice                           round-robin
After creating the table_vars etc... I plug the values into
$(Get-F5.iControl).ManagementApplicationService.create("TestiAPP", "f5.microsoft.iis", $scalar_vars, $list_vars, $table_vars)
The error msg I get is
Exception: Common::OperationFailed
    primary_error_code   : 21954567 (0x014F0007)
    secondary_error_code : 0
    error_string         : script did not successfully complete: (can't read "::net__server_mode": no such
variable
    while executing
"expr {( $::net__server_mode ne "tunnel" &&  [iapp::is ::pool__pool_to_use $::CREATE_NEW_ANSWER] ) ||  (
$::net__server_mode eq "tunnel" &&  [iapp::is ..."
    (procedure "v11_4_main" line 303)
It would seem from the error that either not all the named pairs are being read or $scalar_vars is being cut off part way down. Reordering the pairs simply throws up the same error with a different variable. I have narrowed down that it reads the first two pairs then 'bugs out'.
Can anyone either shed light on this or provide examples?
I'm running 11.5.1 HF5 if it helps.
Regards.
  • It would seem there is a bug with either the 11.5 code base or the f5.microsoft.iis template when reading in scalar values. Trying the same process using .Net SDK renders the same error results as above. If anyone can offer a workaround or solution it would be greatly received.
