mslater905's avatar
mslater905
Nov 19, 2019
Help with HTTPS_Rewrite iRule
Hi all,
I'm currently in a bit of a pickle for developing an iRule solution to avoid HTTPS_Rewrite for certain URL's.
I currently have an LTM VS configured which has a profile that rewrites all redirects to HTTPS.
ltm profile http HTTPS_Rewrite {
  app-service none
  defaults-from http
  enforcement {
    unknown-method allow
  redirect-rewrite all
For most of the redirects, I want the redirect response to be HTTPS which is why this is applied. There are two instances however, where I want the URL redirect to be HTTP.
For instance, for redirects to "www.one.com" & "www.two.com", we don't want the profile to rewrite it to HTTPS.
create ltm rule http-response-specific {
  when HTTP_RESPONSE {
if { HTTP::header value Location contains onetwo-list }
I think replacing the Locaton Variable will be too much of a headache, is it possible to identify the location variable and then bypass the profile entirely for connections with these urls?
Any help would be greatly appreciated!
