Help with Health Monitor
Can someone help me configure this monitoring? What should be the values for GET and other fields?
Health check behavior: HTTP Verb: GET HTTP-200: node available HTTP-503: node failed URL: http:///PRCMD/HealthCheck Poll Frequency: every 10 seconds
Thanks!
- afedden_1985
Cirrus
This is what we use for a http monitor parent is http Advanced Connfiguration settings: 15 second interval 46 second time out 10 seconds till up
the send string , this format will work replace status.aspx with something that's on you servers that return a 200 response code, replace healthcheck.company.domain.name with a host name your server allows Send String: HEAD /status.aspx HTTP/1.1\nHost: healthcheck.company.domain.name \nConnection: close\n\n Receive string just put a 200 in the receive string box
