user1115_113077's avatar
user1115_113077
Jun 24, 2011
Help with Cookie Insertion
Hello,
Currently we're using the following on a vs,
if { [HTTP:uri] starts_with "/clasee*"} {
pool class}
else {
pool main}
We need to add a cookie when request comes in from certain source IPs; we've tried this with no luck so far
if { [matchclass [IP::client_addr] equals "$::class_ip"] } {HTTP::cookie insert name "class" value "class"}
elseif { [HTTP:uri] starts_with "/clasee*"} {pool class}
else {pool main}
Thanks for any help in advance
  • Hi User 1115,
    I think the issue might be in the logic of what are yo trying to do.
    According to your iRule the logic works like this:
    If client ip matches the class_ip datagroup, apply the Cookie Insert and then EXIT the iRule. (NOTE: It will not evaluate the rest of the iRule)
    If client ip does not match the class_ip datagroup, and if the uri starts with "/clasee" then go to pool called class and EXIT the iRule. (NOTE: No Cookie Insert will be invoked)
    If client ip does not match and your URI does not start with /clasee then go to pool main and EXIT the iRule. (NOTE: No cookie Insert will be invoked)
    Is this logic you want?.
    Bhattman
  • Bhattman,
    Thank you for tte explaination and clearly that's not what we want.
    We need to:
    If the client matches the class_ip datagroup, apply the coookient insert AND continue to check the uri, if the uri starts with "/class" go to pool call class, if the uri does not start with "/class" go to pool main and exit the irule. (has cookie)
    If the client does not matches the class_ip datagroup, check the uri, if the uri starts with "/class" go to pool cll class if the uri does not start with "/class" go to pool main and exit the irule. (no cookie)
    We appreicate any help with any rule for the above logic, we're first time irule user.
    Best regards,
  • Hi User1115,
    In that case one of the ways you can do this is the following codes
    This is for version 9.x.x
    Insert cookie if it matches the CLASS_IP datagroup
    if { [matchclass [IP::client_addr] eq $::class_ip] } {
    Choose a pool based on URI
    pool class
    pool main
    OR Using a switch statement
    switch -glob [string tolower [HTTP::uri]] {
    "/clasee*" { pool class }
    default { pool main }
    If you are going to v10 then the code would like like the following
    if { [class match [IP::client_addr] equals "class_ip" } {
    pool class
    pool main
    OR Using a switch statement for v10
    if { [class match [IP::client_addr] equals "class_ip"] } {
    I hope this helps
    Bhattman
  • Hi User1115,
    For debugging you can do the following:
    log local0. "The Source IP: [IP::client_addr] matched. Inserting Cookie"
    if { [HTTP::uri] starts_with "/clasee*"} {
    log local0. "The URL is [HTTP::uri] which is selecting pool class"
    pool class
    log local0. "the URL is [HTTP::uri] which is selecting pool main"
    pool main
    "/clasee*" {
    pool class
    default {
    pool main
    pool class
    pool main
    "/clasee*" {
    pool class
    default {
    pool main
    I hope this helps
    Bhattman
