jpeterson6
Aug 06, 2015Help with configuring F5 load-balancing in between two ASA pairs (full routing)
Hello,
I'm fairly new to F5s, and from what I've been seeing in my searches it appears as though I've really dived into the deep end for complex F5 setups. I've been spending time researching my is...
arpydays
Aug 06, 2015Yeah, the implied directly connected route trumps the static route and as you've found cannot be deleted because of the 'referenced' object protection, in this case a pool in the same network.
There is a way round it though, change the subnet mask on the self-ip to /32 and you should be good to delete it.
cheers
