Help with configuring F5 load-balancing in between two ASA pairs (full routing)
Thanks. Something came up as I made changes and I'm hoping I can get assistance for this as well.
Initially I had set this up so that all the VLANs were on the F5 directly (with their own Self-IP) and would just use Automap to contact the servers, but the customer required all connections (not just outbound) to go through the inside firewall so I had to change that plan to use direct L3 routing.
I've now set all my Virtual Servers to SNAT 'None' and I'm trying to remove the Self-IPs so I can remove those VLANs, but I'm getting errors that some of my Pools will become unreachable, despite the routing that's in place (they fall into the 10.0.0.0/8 space).
Any thoughts on this?
