jharper52's avatar
jharper52
5 years ago
Help troubleshooting AD Auth on F5 LB
Hi All. We're trying to configure AD auth and running into major issues. The strange thing is that telnet succeeds, I've reset and confirmed the bind user's password, and have reset and confirmed the test AD user password. Any help will be much appreciated!
successful connection on 389 and 3269 -
[admin@lb1:Standby:Changes Pending] log # telnet <AD IP> 3269
Trying <AD IP>...
Connected to <AD IP>.
Escape character is '^]'.
[admin@lb1:Standby:Changes Pending] log # telnet <AD IP> 389
Trying <AD IP>...
In /var/log/secure, I see -
Apr 21 19:43:37 lb1 warning httpd[8867]: [warn] [client <IP>] AUTHCACHE Error processing cookie DE71A3EB7E09C285EE804A880D473DA378684CCB - Cookie user mismatch, referer: https://<F5 IP>/tmui/login.jsp?msgcode=1&
Apr 21 19:43:37 lb1 warning httpd[8867]: [warn] [client <IP>] AUTHCACHE Error processing cookie F69E5702BC54A5517DD6CF34EFB66C09E2939501 - Cookie user mismatch, referer: https://<F5 IP>/tmui/login.jsp?msgcode=1&
Apr 21 19:43:37 lb1 warning httpd[8867]: [warn] [client <IP>] AUTHCACHE Error processing cookie ED2B8DAF7E221E2572F7094214AAB91947FE048D - Cookie user mismatch, referer: https://<F5 IP>/tmui/login.jsp?msgcode=1&
Apr 21 19:43:37 lb1 err httpd[8867]: pam_ldap: ldap_simple_bind Can't contact LDAP server
Apr 21 19:43:37 lb1 err httpd[8867]: pam_ldap: reconnecting to LDAP server...
Apr 21 19:43:37 lb1 warning httpd[8867]: pam_unix(httpd:auth): check pass; user unknown
Apr 21 19:43:37 lb1 notice httpd[8867]: pam_unix(httpd:auth): authentication failure; logname= uid=48 euid=48 tty= ruser= rhost=<IP>
Apr 21 19:43:38 lb1 err httpd[8867]: [error] [client <IP>] AUTHCACHE PAM: user 'devf5test' (fallback: false) - not authenticated: Authentication failure, referer: https://<F5 IP>/tmui/login.jsp?msgcode=1&
Apr 21 19:43:38 lb1 info httpd(pam_audit)[8867]: User=devf5test tty=(unknown) host=<IP> failed to login after 1 attempts (start="Wed Apr 21 19:43:37 2021" end="Wed Apr 21 19:43:38 2021").
Apr 21 19:43:38 lb1 info httpd(pam_audit)[8867]: 01070417:6: AUDIT - user devf5test - RAW: httpd(pam_audit): User=devf5test tty=(unknown) host=<IP> failed to login after 1 attempts (start="Wed Apr 21 19:43:37 2021" end="Wed Apr 21 19:43:38 2021").
