cxcal_18687's avatar
cxcal_18687
Feb 04, 2011
HELP: SSL 128 cipher failures
Running 10.1.0
VIP was originally setup to use server pool and a HTTP::redirect to https
That works fine with IE 8 and Firefox.
Discovered clients running IE 7 (with 128 cipher) can not load the page.
How do I correct this?
I'm testing SSL client profile with: DEFAULT:!ADH:!EXPORT40:!EXP:!LOW
Still not working.
Need help urgently.
Thanks.
  • hoolio's avatar
    hoolio
    You can check which ciphers are available for a given cipher string using:
    tmm --clientciphers 'DEFAULT:!ADH:!EXPORT40:!EXP:!LOW'
    You can use ssldump to check what happens in a client and server SSL handshake negotiation:
    sol10209: Overview of packet tracing with the ssldump utility
    http://support.f5.com/kb/en-us/solutions/public/10000/200/sol10209.html
    Aaron
  • Thanks Aaron.
    Is there any documentation on best practices for configuring FTP over SSH?
  • hoolio's avatar
    hoolio
    FTP over SSH or over SSL? LTM cannot offload the encryption for SSH, so you'd just create a virtual server on port 22 and point that at a pool of servers on whichever port(s) the SSH daemon listens on. You could use a Performance L4 virtual server for this.
    For FTPS, it is possible to have LTM decrypt the SSL. I tested this but found that the solution was very dependent on the FTPS client and FTP server types. I'm not sure it's a production-ready solution. The article on this is:
    FTPS Offload via iRules
    http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/340/FTPS-Offload-via-iRules.aspx
    There is a CR noting the request to support FTPS offloading, CR47551. You could contact F5 Support to find out if it has been/is planned to be supported at some point. You can ask them to attach your case to the CR to raise the visibility of the request.
    Aaron
  • Still hitting my head with the following tcpdump during login attempt.. Althought I get the ""fingerprint ssh-rsa" but then get authenication failed:
    Just have the VIP pointing to the server pool, and using L4 profile.
    17:48:56.986258 IP x.22.169.241.1028 > x.36.172.x.ssh: S 758488788:758488788(0) win 65535
    17:48:56.986703 IP x.36.172.x.ssh > x.22.169.241.1028: S 1025121854:1025121854(0) ack 758488789 win 5840
    17:48:57.043374 IP x.22.169.241.1028 > x.36.172.x.ssh: . ack 1 win 32768
    17:48:57.047688 IP x.36.172.x.ssh > x.22.169.241.1028: P 1:21(20) ack 1 win 46
    17:48:57.103653 IP x.22.169.241.1028 > x.36.172.x.ssh: P 1:44(43) ack 21 win 32767
    17:48:57.103931 IP x.36.172.x.ssh > x.22.169.241.1028: . ack 44 win 46
    17:48:57.104957 IP x.36.172.x.ssh > x.22.169.241.1028: P 21:725(704) ack 44 win 46
    17:48:57.109600 IP x.22.169.241.1028 > x.36.172.x.ssh: P 44:556(512) ack 21 win 32767
    17:48:57.109604 IP x.22.169.241.1028 > x.36.172.x.ssh: P 556:684(128) ack 21 win 32767
    17:48:57.109933 IP x.36.172.x.ssh > x.22.169.241.1028: . ack 684 win 63
    17:48:57.165816 IP x.22.169.241.1028 > x.36.172.x.ssh: P 684:700(16) ack 725 win 32762
    17:48:57.167874 IP x.36.172.x.ssh > x.22.169.241.1028: P 725:1005(280) ack 700 win 63
    17:48:57.256547 IP x.22.169.241.1028 > x.36.172.x.ssh: P 700:972(272) ack 1005 win 32760
    17:48:57.263654 IP x.36.172.x.ssh > x.22.169.241.1028: P 1005:1853(848) ack 972 win 71
    17:48:57.355642 IP x.22.169.241.1028 > x.36.172.x.ssh: P 972:988(16) ack 1853 win 32768
    17:48:57.355650 IP x.22.169.241.1028 > x.36.172.x.ssh: P 988:1040(52) ack 1853 win 32768
    17:48:57.355870 IP x.36.172.x.ssh > x.22.169.241.1028: . ack 1040 win 71
    17:48:57.355928 IP x.36.172.x.ssh > x.22.169.241.1028: P 1853:1905(52) ack 1040 win 71
    17:48:57.415586 IP x.22.169.241.1028 > x.36.172.x.ssh: P 1040:1108(68) ack 1905 win 32767
    17:48:57.419579 IP x.36.172.x.ssh > x.22.169.241.1028: P 1905:1989(84) ack 1108 win 71
    17:48:57.482899 IP x.22.169.241.1028 > x.36.172.x.ssh: P 1108:1404(296) ack 1989 win 32766
    17:48:57.523566 IP x.36.172.x.ssh > x.22.169.241.1028: . ack 1404 win 80
    17:49:00.070659 IP x.36.172.x.ssh > x.22.169.241.1028: P 1989:2073(84) ack 1404 win 80
    17:49:00.209323 IP x.22.169.241.1028 > x.36.172.x.ssh: R 1404:1404(0) ack 2073 win 0
    17:49:14.280379 IP x.22.169.241.iad3 > x.36.172.x.ssh: S 4106293492:4106293492(0) win 65535
    17:49:14.280606 IP x.36.172.x.ssh > x.22.169.241.iad3: S 3350075743:3350075743(0) ack 4106293493 win 5840
    17:49:14.337254 IP x.22.169.241.iad3 > x.36.172.x.ssh: . ack 1 win 32768
    17:49:14.341342 IP x.36.172.x.ssh > x.22.169.241.iad3: P 1:21(20) ack 1 win 46
    17:49:14.399249 IP x.22.169.241.iad3 > x.36.172.x.ssh: P 1:44(43) ack 21 win 32767
    17:49:14.399902 IP x.36.172.x.ssh > x.22.169.241.iad3: . ack 44 win 46
    17:49:14.400284 IP x.36.172.x.ssh > x.22.169.241.iad3: P 21:725(704) ack 44 win 46
    17:49:14.403021 IP x.22.169.241.iad3 > x.36.172.x.ssh: P 44:556(512) ack 21 win 32767
    17:49:14.403026 IP x.22.169.241.iad3 > x.36.172.x.ssh: P 556:684(128) ack 21 win 32767
    17:49:14.403247 IP x.36.172.x.ssh > x.22.169.241.iad3: . ack 684 win 63
    17:49:14.457271 IP x.22.169.241.iad3 > x.36.172.x.ssh: P 684:700(16) ack 725 win 32762
    17:49:14.459805 IP x.36.172.x.ssh > x.22.169.241.iad3: P 725:1005(280) ack 700 win 63
    17:49:14.548367 IP x.22.169.241.iad3 > x.36.172.x.ssh: P 700:972(272) ack 1005 win 32760
    17:49:14.555198 IP x.36.172.x.ssh > x.22.169.241.iad3: P 1005:1853(848) ack 972 win 71
    17:49:14.746744 IP x.22.169.241.iad3 > x.36.172.x.ssh: . ack 1853 win 32768
    17:49:28.156578 IP x.22.169.241.iad3 > x.36.172.x.ssh: P 972:988(16) ack 1853 win 32768
    17:49:28.157029 IP x.22.169.241.iad3 > x.36.172.x.ssh: P 988:1040(52) ack 1853 win 32768
    17:49:28.157251 IP x.36.172.x.ssh > x.22.169.241.iad3: . ack 1040 win 71
    17:49:28.157255 IP x.36.172.x.ssh > x.22.169.241.iad3: P 1853:1905(52) ack 1040 win 71
    17:49:28.216186 IP x.22.169.241.iad3 > x.36.172.x.ssh: P 1040:1108(68) ack 1905 win 32767
    17:49:28.219039 IP x.36.172.x.ssh > x.22.169.241.iad3: P 1905:1989(84) ack 1108 win 71
    17:49:28.356048 IP x.22.169.241.iad3 > x.36.172.x.ssh: P 1108:1404(296) ack 1989 win 32766
    17:49:28.396201 IP x.36.172.x.ssh > x.22.169.241.iad3: . ack 1404 win 80
    17:49:29.760217 IP x.36.172.x.ssh > x.22.169.241.iad3: P 1989:2073(84) ack 1404 win 80
    17:49:30.033536 IP x.22.169.241.iad3 > x.36.172.x.ssh: . ack 2073 win 32766
    17:49:30.128949 IP x.22.169.241.iad3 > x.36.172.x.ssh: R 1404:1404(0) ack 2073 win 0
