cdjac0bsen's avatar
cdjac0bsen
6 years ago
Solved
Help simulating ASM syslog events at error level and above for testing?
Does anyone have a suggestion on how to generate system events on an ASM at error, critical, or emergency levels for testing remote syslog logging?
  • Hi,
    you can use the logger command to generate a log message manually
    logger -p <facility>.<level> "<descriptive message>"
    [admin@F5BIPIP:Active:In Sync] ~ # logger -p local0.notice "testing LTM facility level notice"
    [admin@F5BIPIP:Active:In Sync] ~ # tail -f /var/log/ltm
    Apr 24 08:16:14 F5BIPIP notice admin[29591]: testing LTM facility notice
    More details here : https://support.f5.com/csp/article/K86480148
    Regards
  • Hi,
    Regards
    • cdjac0bsen's avatar
      cdjac0bsen
      ​That worked perfectly, thanks!  The events even show up in the GUI.
