totengraber_937
Dec 13, 2007Help Replacing characters in URI(URL?)
Okay, I've tried to do this on my own, but have gotten no where.
It has been discovered that our web application is vulnerable to Cross-Site Scripting based on tests from ScanAlert.
I have looked into ASM, but the company is reluctant to spend the money on new hardware since our current hardware won't run the ASM.
What I would like to do is replace <,>,(,) in the URI(URL)to their proper HTML equivalents. I have yet to get any iRule to even come close to doing this.
I would appreciate anyone's help if they have some pointers to help me on my way.
Thanks,
Todd
- What do you mean by "HTML equivalent"? Do you mean HTTP encoded, or HTML encoded. The two are different.
URL encoding: "<" -> "%3c"
HTML Encoding: "<" -> "& lt;"
If it is the URL encoding you want, you can easily do so with the URI::encode iRule commandwhen HTTP_REQUEST { HTTP::uri [URI::encode [HTTP::uri]] }
This will turn "/foobar(foo)" into "%2ffoo%3cbar%3ebar(foo)"
If you want to do HTML encoding, then you'll have to do a manual string map of what you want to convert.when HTTP_REQUEST { HTTP::uri [string map { "<" "<" ">" ">" } [HTTP::uri]] }
This will convert "/foobar(foo)" into "/foobar(foo)"
As far as I know there is not a URI or HTML encoded value for parenthesis but you can extend the last iRule above to whatever translation you want.
Hope this helps...
-Joe
