jcook_105986's avatar
jcook_105986
Jul 07, 2008
help on "ManagementLicenseAdministration" methods
iControl.ManagementLicenseAdministrationEvaluationExpiration iContorlTime =
m_interfaces.ManagementLicenseAdministration.get_evaluation_license_expiration();
DateTime n_expTime = new DateTime(iContorlTime.evaluation_expire);
Above code does not return the same value as what i see from the web based F5 interface.
"get_evaluation_license_expiration" method comes back with different time from
the actuall system.
n_expTime is keep on returning "2001-01-01 00:00"
I dont really mind, even if I get weird value from the
"get_evaluation_license_expiration" function, as long as the value I get is
same as the web based F5 interface.
Im 99% sure that, this is my fault, but could you plz try to guess
what Im doing wrong here.
Thank you
  • Anthony_Gerace_'s avatar
    Anthony_Gerace_
    Historic F5 Account
    Hi JCook,
    How are you handling the date conversion? The return values from get_evaluation_license_expiration method are longs and represent the number of seconds from the epoch. Here is a PERL example I used for testing.
    HTH,
    Anthony
    $soap = SOAP::Lite
           -> uri('urn:iControl:Management/LicenseAdministration')
           -> proxy("https://$host/iControl/iControlPortal.cgi");
     $soap_response = $soap->get_evaluation_license_expiration;
     if (! $soap_response->fault ) {
       $evalExp = $soap_response->result;
       $expEval = $evalExp->{evaluation_expire};
       $expDate = ParseDateString("epoch $expEval");
       print $expDate;
  • Check out my tech tip on License Administration, it shows how to convert the epoch time to local time with PowerShell (which should translate to .Net nicely).
    http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=214
    Click here
    -Joe
