midhun_108442
Jan 20, 2012Help need to create a irule for limit Client Connection
Can anyone help us to create a irule to limit number of client connection hitting to Virtual server , I got the same irule scenario in Dev central site for (iRule.Limit Connection from Client) , but thats not working with me its only logging the message not blocking the connection ,Kindly anyone help me to provide the irule for the same.
Regards,
Midhun P.K
- hoolio
You can take Thomas's logic and store the hosts and/or networks in a data group with the values set for the connection limit.Data group mapping hosts/networks to connection limit values class conn_limit_dg { network 10.0.0.0/8 { "5" } network 192.168.0.0/16 { "5" } host 172.16.1.1 {"10"} }From http://devcentral.f5.com/wiki/iRules.table.ashx Limit each client IP address to 20 concurrent connections when CLIENT_ACCEPTED { Max connections per client IP set limit [class match [IP::client_addr] equals conn_limit_dg] Set a subtable name with a standard prefix and the client IP set tbl "connlimit:[IP::client_addr]" Use a key of the client IP:port set key "[IP::client_addr][TCP::client_port]" Check if the subtable has over X entries if { [table keys -subtable $tbl -count] >= $limit } { log local0. "[IP::client_addr]:[TCP::client_port]: Rejecting connection ([table keys -subtable $tbl -count] connections / limit: $limit)" reject } else { Add the client IP:port to the client IP-specific subtable with a max lifetime of 1800 seconds (30min) table set -subtable $tbl $key "ignored" 1800 log local0. "[IP::client_addr]:[TCP::client_port]: Allowing connection ([table keys -subtable $tbl -count] connections / limit: $limit)" } } when CLIENT_CLOSED { When the client connection is closed, remove the table entry table delete -subtable $tbl $key log local0. "[IP::client_addr]:[TCP::client_port]: Decrementing ([table keys -subtable $tbl -count] connections / limit: $limit)" }
Once you're done testing, make sure to comment out the log statements.
Aaron - midhun_108442
Hi Aaron/Thomas,
Thanks for you support.
I have configured the Irule and tested , its working fine .
Provided Irule wil block all Tcp connection , but i m looking for http/s request per client connection and i got the irule which match our requirement and tested its working , below is the Irule FYI
when RULE_INIT {
this is the life timer of the subtable object. defines how long this object exist in the subtable
set static::maxRate 10
This defines how long is the sliding window to count the requests. This example allows 10 requests in 3 seconds
set static::windowSecs 3
set static::timeout 30
if { [HTTP::method] eq "GET" } {
set getCount [table key -count -subtable [IP::client_addr]]
log local0. "getCount=$getCount"
if { $getCount < $static::maxRate } {
incr getCount 1
table set -subtable [IP::client_addr] $getCount "ignore" $static::timeout $static::windowSecs
log local0. "This user $user has exceeded the number of requests allowed. "
HTTP::respond 501 content "Request blockedExceeded requests/sec limit."
return
can u help me to chnage this irule base on different connection limit for each client by using data group,
Appreciate your support on this - midhun_108442
Hi Aaron/Thomas,
when RULE_INIT {
incr getCount 1
return
Appreciate your support on this - hoolio
Try Hamish's example for 10.1 or higher:
http://devcentral.f5.com/wiki/iRules.HTTP_Session_Limit.ashx
Hi Aaron,
Irule which i sent you is working for me but ,that will block all client connection with the same connection limit , is it possible to rewrite the irule for each client having different connection limit on the same irule .
Regards,
Midhun P.K - hoolio
I think this should work if you've defined the host/network = limit pairs in the conn_limit_dg data group.when RULE_INIT { This defines how long is the sliding window to count the requests. This example allows 10 requests in 3 seconds set static::windowSecs 3 set static::timeout 30 } when CLIENT_ACCEPTED { Max connections per client IP set limit [class match [IP::client_addr] equals conn_limit_dg] log local0. "[IP::client_addr]: \$limit: $limit" } when HTTP_REQUEST { if { [HTTP::method] eq "GET" } { set getCount [table key -count -subtable [IP::client_addr]] log local0. "getCount=$getCount" if { $getCount < $limit} { incr getCount 1 table set -subtable [IP::client_addr] $getCount "ignore" $static::timeout $static::windowSecs } else { log local0. "[IP::client_addr]: exceeded the number of requests allowed. $getCount / $limit" HTTP::respond 501 content "Request blockedExceeded requests/sec limit." } } }
Hi Aaron,
I have applied the above irule by creating Data Group "conn_limit_dg" defining Host with a vlue of 10a , but its not working ,The Web page is opening on every first request but its blocking after that and i can see the logs that my request is not crossing above 1 , below are my logs and attached screen-shot for Data Group entry , Kindly lookin to this and helpme to fix this.
Thu Jan 26 14:19:44 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test2 : getCount=0
Thu Jan 26 14:41:07 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test2 : getCount=0
Thu Jan 26 14:44:35 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test4 : getCount=0
Thu Jan 26 14:44:35 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : getCount=1
Thu Jan 26 14:44:35 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test4 : getCount=1
Regards,
Midhun p.k - hoolio
Hi Midhun,
Can you try using this version with some additional debug logging?when RULE_INIT { This defines how long is the sliding window to count the requests. This example allows 10 requests in 3 seconds set static::windowSecs 3 } when CLIENT_ACCEPTED { Max connections per client IP set limit [class match -value [IP::client_addr] equals conn_limit_dg] log local0. "[IP::client_addr]: \$limit: $limit" } when HTTP_REQUEST { if { [HTTP::method] eq "GET" } { set getCount [table key -count -subtable [IP::client_addr]] log local0. "[IP::client_addr]: getCount=$getCount" if { $getCount < $limit} { incr getCount 1 table set -subtable [IP::client_addr] $getCount "" indefinite $static::windowSecs } else { log local0. "[IP::client_addr]: exceeded the number of requests allowed. $getCount / $limit" HTTP::respond 501 content "Request blocked. Exceeded requests/sec limit." } } }
Hi Aaron,
I have applied the rule and run the test , below are the logs message ,it shows Allowed maximum connection for the client is "1" and thats why its blocking my request randomly.
but i have allowed 10 connection for the client in Data Group list, but the script not taking that value, attached the screenshot of Datagroup list configuration FYI.
Thu Jan 26 23:59:38 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test4 : 192.168.249.14: $limit: 1
Thu Jan 26 23:59:38 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test4 : 192.168.249.14: getCount=0
Thu Jan 26 23:59:39 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test4 : 192.168.249.14: $limit: 1
Thu Jan 26 23:59:39 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test4 : 192.168.249.14: getCount=1
Thu Jan 26 23:59:39 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test4 : 192.168.249.14: exceeded the number of requests allowed. 1 / 1
Thu Jan 26 23:59:45 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test4 : 192.168.249.14: getCount=0
Thu Jan 26 23:59:46 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test4 : 192.168.249.14: $limit: 1
Thu Jan 26 23:59:46 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test4 : 192.168.249.14: getCount=1
Thu Jan 26 23:59:46 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test4 : 192.168.249.14: exceeded the number of requests allowed. 1 / 1
Thu Jan 26 23:59:48 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test4 : 192.168.249.14: getCount=1
Thu Jan 26 23:59:48 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test4 : 192.168.249.14: exceeded the number of requests allowed. 1 / 1
Thu Jan 26 23:59:50 AST 2012 info local/tmm1 tmm1[5126] Rule limt-test4 : 192.168.249.14: getCount=0
Thu Jan 26 23:59:50 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: $limit: 1
Thu Jan 26 23:59:50 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: getCount=1
Thu Jan 26 23:59:50 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: exceeded the number of requests allowed. 1 / 1
Thu Jan 26 23:59:51 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: getCount=1
Thu Jan 26 23:59:51 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: exceeded the number of requests allowed. 1 / 1
Thu Jan 26 23:59:53 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: getCount=1
Thu Jan 26 23:59:53 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: exceeded the number of requests allowed. 1 / 1
Thu Jan 26 23:59:54 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: getCount=0
Thu Jan 26 23:59:55 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: $limit: 1
Thu Jan 26 23:59:55 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: getCount=1
Thu Jan 26 23:59:55 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: exceeded the number of requests allowed. 1 / 1
Thu Jan 26 23:59:56 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: getCount=1
Thu Jan 26 23:59:56 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: exceeded the number of requests allowed. 1 / 1
Thu Jan 26 23:59:57 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: getCount=1
Thu Jan 26 23:59:57 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: exceeded the number of requests allowed. 1 / 1
Thu Jan 26 23:59:59 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: getCount=0
Fri Jan 27 00:00:00 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: $limit: 1
Fri Jan 27 00:00:00 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: getCount=1
Fri Jan 27 00:00:00 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: exceeded the number of requests allowed. 1 / 1
Fri Jan 27 00:00:01 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: getCount=1
Fri Jan 27 00:00:01 AST 2012 info local/tmm tmm[5125] Rule limt-test4 : 192.168.249.14: exceeded the number of requests allowed. 1 / 1 - hoolio
Sorry for missing this... the class match command was missing the -value flag so it was just returning 1 for true (meaning the client IP was found in the data group). Using the -value flag indicates class match should return the value for the corresponding data group key. I've edited my post above with the update. Can you try that instead?
Thanks, Aaron
