gavincheng_1049
Apr 02, 2010Help me,why HA fail ?
Hello,all.
I used to two virtual BIGIP that HA Lab, but fail,
the two BIGIP version is "BIG-IP 10.1.0 Build 3341.1084 Final "
BIGIP_1-------(HA mode Network Failover )--------BIGIP_2
HA mode Active-active
High Availability : Redundancy, unit 1 of BIGIP_1 device,unit 2 of BIGIP_2 device.
BIGIP_1: ConfigSync Peer Address set 198.18.19.252 ,BIGIP_1 management ip address is 192.168.0.105
BIGIP_2: ConfigSync Peer Address set 198.18.19.251 ,BIGIP_2 management ip address is 192.168.0.106
Detect ConfigSync Status enable
BIGIP_1: failover1|198.18.19.251|198.18.19.252|1026
failover2|192.168.0.105|192.168.0.106|1026
BIGIP_2: failover1|198.18.19.252|198.18.19.251|1026
failover2|192.168.0.106|192.168.0.105|1026
network mirroring:
BIGIP_1:Self _198.18.19.251,remote_198.18.19.252
BIGIP_2:Self _198.18.19.252,remote_198.18.19.251
High Availability-Fail_self--gateway:
add pool : failover_pool, pool member only include 198.18.19.1(default gateway),health moniter select "gateway_icmp"
ok, them can Synchronize configuration,but not switch over ,
down BIGIP_2 , BIGIP_1 can't take over BIGIP_1 's traffic .
b unit command on BIGIP_1 , display unit 1 :
[root@BIGIP_1:Active] config b unit
UNITS 1
reboot BIGIP_2, b failover standby command on BIGIP_2,and b unit command on BIGIP_1,dispaly:
UNITS 1 and 2
but shutdown BIGIP_2,
[root@BIGIP:Active_] config b unit
UNITS 1 and 2
why ? ?
more /var/log/ltm
Apr 2 23:04:07 local/BIGIP notice sod[2598]: 010c0044:5: Command: go failback BIGpipe.
Apr 2 23:04:25 local/BIGIP notice sod[2598]: 010c0020:5: Unit 1 and 2
Apr 2 23:05:00 local/BIGIP notice sod[2598]: 010c0020:5: Unit 1
Apr 2 23:05:03 local/BIGIP notice mcpd[2596]: 01070640:5: Node 198.18.19.252 monitor status down.
Apr 2 23:05:03 local/tmm err tmm[3626]: 01010028:3: No members available for pool failover_pool
Apr 2 23:05:05 local/BIGIP notice mcpd[2596]: 01070638:5: Pool member 198.18.19.252:0 monitor status down.
how kill this problem ? HA still does not work, switch to complete the normal process of proposed solutions or have you ideas?
Thanks !
- hoolio
Hi Gavin,
HA configurations aren't supported for the virtual edition. This limitation is described in the VE 10.1.0 release notes (Click here). A poster (Click here) suggested that he got HA to work though.
It seems like your HA configuration might be working, but the monitor is marking the gateway down. You might try focusing your troubleshooting on why the unit can't ping the failover_pool member.
Aaron - gavincheng_1049
hi hoolio,
thanks for your reply, I think HA configrations suppored for virtual edition, now, my two virtual bigip HA state is ok,
unit 1 of bigip ,unit 2 of bigip . HA mode active-active
on bigip unit 1 ,type : b failover standby , and on bigip unit 2 ,type: b unit , display : unit 1 unit 2 , so HA is ok .
on bigip unit 2 ,type : b failover standby , and on bigip unit 1 ,type: b unit , display : unit 1 unit 2 , so HA is ok .
are you know ?
but power off BIGIP unit 1 , on BIGIP unit 2 b unit ,display: unit 2 , not display unit 1 unit 2 , I don't understand this .
again ,power off BIGIP unit 2 , on BIGIP unit 1 b unit ,display: unit 1 , not display unit 1 unit 2 ,
why ,why ?
by the way , I creat same singel virtual server(VIP) on BIGIP 1 and BIGIP 2 , define virtual server name is "WebServer"" ,
Power off BIGIP 1 or BIGIP 2 ,external client can connect "WebServer" ,if "WebServer" unit set 1 on BIGIP 1 and "WebServer" unit set 1 on BIGIP 2.
Power off BIGIP 1 or BIGIP 2 ,external client can't connect "WebServer" ,if "WebServer" unit set 1 on BIGIP 1 and "WebServer" unit set 2 on BIGIP 2.
why ? - gavincheng_1049
waiting reply - JRahm
Admin
HA is definitely NOT supported on VE at this time. - hoolio
https://support.f5.com/kb/en-us/products/big-ip_ve/releasenotes/product/relnotes_ve_10_1_0.htmlunsupported_feat
Unsupported BIG-IP system features
This product does not support the following BIG-IP system features:
* Optional BIG-IP system modules, such as Global Traffic Manager™, Application Security Manager™, WAN Optimization Module™, and WebAccelerator™.
* Redundant system configuration
* Advanced SSL functions. Note that BIG-IP VE Trial supports OpenSSL ciphers only, and not F5 Networks cipher implementations.
* Advanced TCP profile settings
oh,My God ,it's surprised.
thanks for all . good for you
