InfoSec_38553
Dec 27, 2010help me with handshake logs
I'm experienced error while third party was trying to connect to my service using client certificate.
I did tcpdump attached the result.
Can you help me to find the problem.
- hoolio
Hi InfoSec,
The ssldump output shows the server rejected the client's certificate:1 7 1293361272.9715 (0.0011) S>CV3.1(2) Alert level fatal value handshake_failure
If you can get a copy of the client's cert and key, you could test this yourself. The first thing I'd try is to use openssl s_client to check that the client cert is valid for the server cert.
http://www.openssl.org/docs/apps/s_client.html
Aaron - InfoSec_38553
Thank you very much.
This was very helpful the problem fixed now.
Regards, - hoolio
Out of curiosity, what was the fix?
Thanks, Aaron - InfoSec_38553
Actually the problem was from the certificate itself signed in wrong way.
This why it was reject by the server.
