jay_Echo_202019's avatar
jay_Echo_202019
Aug 01, 2015
Help Lost my F5 after Software activation
I had Version 11.1 and installed version 11.6 on my LTM 3900 the I wen via web interface and told it to boot from the disc containing the new version. And since nada the unit is not responding to ping from Management interface or any of the active interface. All my sites are down please help
  • I ran some cammands I found on this site abd here is the result. This unit was fine an hour ago echo@(f5)(cfg-sync Standalone)(INOPERATIVE)(/Common)(tmos) restart sys s ervice all echo@(f5)(cfg-sync Standalone)(INOPERATIVE)(/Common)(tmos) Aug 1 20:46: 49 f5 emerg mcpd[21476]: 0107070e:0: Software version not covered by service agr eement. Reactivate license before continuing. Aug 1 20:46:49 f5 emerg mcpd[21476]: 01070608:0: License is not operational (ex pired or digital signature does not match contents). Aug 1 20:46:52 f5 emerg load_config_files: "/usr/bin/tmsh -n -g load sys config partitions all base" - failed. -- 01070712:3: Failed: name (/Common/dtca.crt) N o copy in trash-bin to restore from. Unexpected Erro r: Loading configuration process failed. appservervice none Syntax Error: unexpected argument "appservervice" echo@(f5)(cfg-sync Standalone)(INOPERATIVE)(/Common)(tmos) restart sys service all
  • Now I can no longer login login as: echo Using keyboard-interactive authentication. Password: Last login: Sat Aug 1 20:59:25 2015 from 10.1.1.105 01070827:3: User login disallowed: User (echo) is not an administrator, does not have a UID of zero, and has not been assigned a role on a partition. Current session has been terminated. Enter any key to end your session.
