Help. I have deleted a RSA key. Is there any way to retrieve this key?
The key was not archived. I have the original csr - is there a process to re-create the RSA key from this?
Hope someone can help, Nige
- pete_71470
Is the F5 unit part of an HA pair? If you haven't synchronized configurations, you might be able to fetch the key from the Standby unit.
I don't know when this directory was introduced, but it's on our 11.2.1 systems:
/config/filestore/.trash_bin_d/
Under this directory I found a certificate I deleted almost a year ago; perhaps the keys are under this directory as well?
- NIGEL_CLEMENT_6
Star man. Got it. Thanks for your help.
- M_2
Altocumulus
did that worked? Does the folder contains all the deleted certs and keys ?
-Sam
- nitass
Employee
yes but i understand trash bin is cleaned up when rebooting a unit (i.e. tmsh load sys config).
- M_2
Altocumulus
Thank` you for the information :)
