Fahad_A__Bin_Ma
Nov 21, 2007help!! how Oracle 11i can work with LTM
i have oracle 11i and its working fine. I want to do load balances between two Oracle server by LTM. i go by the F5 guide to do every thing. The missing point with me is Oracle part. i don’t now what is the change i need to do on oracle so every thing will be done on it. i dont have much idea on oracle so if one can give me the step by step will be grate. Help!!!
- hoolio
Are you trying to load balance an Oracle web application? If so, have you been able to configure a pool with the Oracle servers and point a virtual server at the pool? If I'm off the mark here, can you provide detail on exactly what you're trying to do and what's not working?
Aaron
