Health Monitor Required
I need to prepare the health monitor which will fulfill me below requirement.Please suggest.If u write & share the irule will be helpful.
type HTTP port tcp/80 http method: GET http url: /ldprobe.htm expect status code in responses: range from 200 to 999
- Jinshu
Cirrus
Hello Friend,
You can configure a simple health monitor using GET method.
1. Navigate to Local Traffic ›› Monitors ›› New Monitor. 2. Enter Name and Type HTTP 3. Send String - GET /ldprobe.htm HTTP/1.1\r\nHost: \r\nConnection: Close\r\n\r\n 4. Receive String - 200 OK 4. FinishHope this helps.
btw, Is there any specific requirement for iRule to probe health monitor?
-Jinshu
Hi
as the previos poster have already recommended, you should use a LTM Monitor to test the health of your application.
To allow status codes between 200 and 999 you have to define the Receive String using regular expression...
Send String : GET /ldprobe.htm HTTP/1.1\r\nHost: www.insert-your-domain-name.tld\r\nConnection: Close\r\n\r\n Receive String : HTTP/1.(0|1) [2-9][0-9][0-9]Cheers, Kai
- Jinshu
Cirrus
As i mentioned earler the 'Receive String - 200 OK' would be fine for you as per your curl output.
-Jinshu
