Julio_Navarro
Mar 09, 2016Health Monitor | HA Environment
Hello;
I have two LTMs in a HA Config : Active/Standby.
Now, I have health monitor (http,https) checking the members status. In the members's IIS logs that are being monitored by the healthmonitor, the standby LTM don't always shows compare to the the active LTM.
Is this normal?
J
Hi J.,
every unit in the HA-Group should use the same health monitoring frequency (unless external monitors with added logic to skip certain checks on standby systems is used).
So its not a normal behavior...?
Cheers, Kai
