jpeterson6's avatar
jpeterson6
Aug 10, 2017
Having an issue with creating an iRule using HTTP::Path
Hello,
When I try creating an iRule I get the following error (I'm on v12.1.2):
error: [undefined procedure: HTTP::Path][HTTP::Path]
Here is the iRule (slight edit on URLs for security reasons):
    if { [class match [IP::client_addr] equals example_dg] } {
        switch -glob [string tolower [HTTP::Path]] {
            "/test/url/*" -
            "/test/this/url/*" {
                event disable
            default {
                reject
I do not see anything wrong with this rule in the syntax - but I've been staring at it for awhile and might have gone blind to what may be causing it.
Is anyone able to shed some light?
  • Hi,
    The right syntax is
    HTTP::path
    and not
    HTTP::Path
    The word path is lowercase
