Cyril_M's avatar
Cyril_M
Oct 12, 2011
Have you heard of major IE bug not sending HTTP re-POST body ??
Hi all !
We found out that our application using AJAX is randomly unresponsive because of a known bug of Internet Explorer, from version 6 to version 9 !
What sounds incredible is that Microsoft published a patch, but it has to be activated manually by editing the registry !!
You can find more information about the issue here :
http://www.eggheadcafe.com/software...paliv.aspx
http://stackoverflow.com/questions/...er-failure
and Microsoft's workaround is available here :
http://support.microsoft.com/kb/895954
The problem is that it's not possible to ask visitors to patch their IE ! So we must set up our own workaround ...
My questions are : did you already face this issue ? And do you think that a workaround could be found using F5 features ??
Thanks for your help
  • Hi Cyril,
    Unfortunately this is something that the clients would need patch.
    Bhattman
