Has anyone tried an APM webtop to launch XenApp using anonymous logins?
I want to use LDAP auth out in front of a webtop, then present some links to Citrix apps that use anonymous logins on the backend. It is for a very simple demo system. Curious if any of you have tried such a thing.
I started with a XenApp iApp and I will hack from there. I'll answer myself if I get it to work. Thanks!
- Thomas_Gobet
On which version are you runnning on ?
You should fine log on informations into your Remote Desktop application in APM. Just click on "Auto Logon" and you will can set Broker Authentication with your anonymous account.
