Shiva_Chetan_34's avatar
Shiva_Chetan_34
Nov 28, 2017
HA Group not handing over- score always 0
I have a similar problem as this one. My score of HA group is always 0
https://devcentral.f5.com/questions/ha-group-score-always-0-problem-solved-46182
but the answer is removed from this.. HELP!!
Also, in my setup of 2 load balancers, the LB with lower management address is handing over to the other LB in case of failure of HA Group. but the other LB with higher management address is not handing over in case of HA group failure. What do I do to make the device (with higher management address) hand over. Thank you for your help.
Shiva Chetan
  • Can you provide your HA Group's configuration as well as output to a tmsh show /sys ha-group detail command, please?
