HA failover with no session lost is possible ?
Hello I have Active/Standby HA configuration on our BIG-IP LTM appliance. I'm not able to figure out if forcing a failover I'll lose client session or not.
doing "(tmos) show sys connection cs-client-addr x.x.x.x" on active and on standby unit doesn't give the same result, this drive my to think that no session faiover is supported.
Is session failover supported ? How can I check that ?
Thank you in advance.
- Mike_61663
Cirrus
If you're mirroring connections between the BIG-IPs then those connections should persist after failover. The general recommendation is for long lived connections like SSH and FTP that you would want to mirror those connections but for short lived connections like HTTP it's generally not worth the overhead.
You have to configure mirroring between the devices in the cluster and then enable it for each virtual server that you want to use it. It's not enabled by default.
Check out the following solution doc for far more information on the topic. SOL13478 - Overview of connection and persistence mirroring (11.x)
- Vitaliy_Savrans
Nacreous
In addition to Mike answer, connection mirroring is not supported in combination with a Client SSL or Server SSL profile.
it seems ssl session mirroring in now possible: https://devcentral.f5.com/articles/the-top-ten-hardcore-f5-security-features-in-big-ip-116
now only connection mirroring :)
BTW: F5 web search team when i search for ssl session mirroring f5 i find a website posting the full article way before the actual page.
- ipman_1988_5418
In BIG-IP 12.0.0 and later, you can configure the system to mirror Secure Socket Layer (SSL) connections that are terminated by the BIG-IP system to peer device group members. When you enable connection mirroring on a virtual server that references an SSL profile, the BIG-IP system mirrors SSL-specific data to the appropriate device group member. This preserves SSL connections when failover occurs.
The following configuration options are not supported for virtual servers configured to mirror SSL connections: •HTTP profiles (12.0.0 - 12.1.2)* •Server SSL profiles (12.0.0 - 12.1.2)* •UDP profiles •iRules (12.0.0 - 12.1.2)* •Other L7 features
*Support for these configuration options is introduced in BIG-IP 13.0.0.
