Ricardo_Raza_14
Jun 26, 2014HA between 3600 and 3900
Hi do you know if its possible have HA between device 3600 and 3900?
- Ben_Newport_102
Its possible. We do UCS restores from 5000 to 3900. When the interfaces don't match up you will be warned when doing the restore and will have to modify config files, but 3600 to 3900 have the same ports. Just need to be sure that the same modules are registered on both.
- Ricardo_Raza_14
Thanks for the answer, further its mandatory that the 2 device have the same version?
- Ben_Newport_102
yes same version, hotfix, and engineering level if you are on one.
