Manu_240242's avatar
Manu_240242
Sep 14, 2017
GTM load balancing
I want to know how to write a irule to check GTM functionality that 99 my request goes to DC and then 1 request to my DR site is this achievable by irule or LB methods.
  • You can use GTM wide ip ratio lb method.
    You can define the ratio on the pools created and select ratio lb method to achieve your requirement.
    -Jinshu
