samstep
Cirrocumulus
May 07, 2008GTM iRule RULE_INIT does not work?
The following code does not seem to work in GTM iRule (no errors generated, simply nothing is written to the log)
when RULE_INIT {
log local0. "LOG SOMETHING HERE"
The same obviously works fine as LTM iRule.
Is this a known issue?
- golden_53157Historic F5 AccountThis is a known issue and is being tracked.
- hoolio
Out of curiosity, what's the CR? Can you provide a bit more detail on what the issue and significance are? Is it just that log statements don't work? Or is any command in RULE_INIT ignored?
Thanks,
Aaron - golden_53157Historic F5 AccountThe CR number is 95407. The problem is that rule_init is broken, so it does not have to do with the log command.
- Colin_Walker_12Historic F5 AccountThanks for the update, good to know this one's on the books.
Colin
