GTM - Configuring two listner IPs to resolve external & internal url with same FQDN
Scenario - We have scenario where we need to use URL with same FQDN in LAN & Internet. This can be done with GTM using single listener IP.
Query - Is it possible to achieve this scenario using two listener Ips one for LAN & another for Internet?
- stan_piron
Cumulonimbus
what do you need? create 2 listeners for both internal and external users or resolve queries with internal IP if request source is internal?
- IheartF5_45022
Nacreous
Absolutely - I always dual-home my GTMs with internal/external listeners.
You can then use either topology records or iRule (horses for courses) to emulate DNS views. Here is a good link to configuring topology records for split view DNS.
- Rupesh_M
Thanks for your reply.The document is useful , gives complete insight. It is require to configure topology based on source IPs. Can it be done based on listner IP , instead of source IP ? That is, if request is comming from external listner IP then resolve external pool and if request is comming from internal listner IP then resolve internal pool.
- stan_piron
Cumulonimbus
you can create pool external and internal with the following method:
- external pool : exchange_pool
- internal pool : exchange_pool_int (append _int prefix)
and use the following irule in wide IPs
when DNS_REQUEST { if { [IP::addr [IP::local_addr] equals X.X.X.X] } { pool "[DNS::rrname]_int" } }
