Brian_Hayes_118's avatar
Brian_Hayes_118
Aug 12, 2009
Get a CommonEnabledState from Monitor State
Hello all - I have been working on code to gracefully shut down a node of a pool, I followed the examples in the code repo but what I could never find was a way to get a CommonEnabledState from the methods like you can get from the session state. I wasn't concerned about this until I started to think about users issuing a CommonEnabledState on a node when it is already in that state (both session and/or monitor).
I am using BIG-IP_v9.3.1 and java 5.0.
To get the Session information it returns CommonEnabledState object.
      * @param member
      *            - The {@link BigIPPool.PoolMember} who's session state you need.
      * @return - {@link CommonEnabledState} of the given pool member.
      * @throws RemoteException
      * @throws Exception
     public static CommonEnabledState getPoolMemberSessionState(BigIPPool.PoolMember member) throws RemoteException, Exception {
         String[] poolname = new String[] { member.getBigIPPoolName() };
         LocalLBPoolMemberPortType lbpool = BigIP.getIControlInterFace().getLocalLBPoolMember();
         LocalLBPoolMemberMemberSessionState[][] poolStates = lbpool.get_session_enabled_state(poolname);
         for (LocalLBPoolMemberMemberSessionState[] memberStates : poolStates) {
             for (LocalLBPoolMemberMemberSessionState memberState : memberStates) {
                 if (member.getPortDefinition().equals(memberState.getMember())) {
                     return memberState.getSession_state();
         return null;
When I try to do the same thing for the monitor it returns a different object.
      * @param member
      *            - The {@link BigIPPool.PoolMember} who's monitor state you need.
      * @return - {@link LocalLBMonitorStatus} of the given pool member.
      * @throws Exception
     public static LocalLBMonitorStatus getPoolMemberMonitorState(BigIPPool.PoolMember member) throws RemoteException, Exception {
         LocalLBPoolMemberMemberMonitorStatus[][] poolStates = lbpool.get_monitor_status(poolname);
         for (LocalLBPoolMemberMemberMonitorStatus[] memberStates : poolStates) {
             for (LocalLBPoolMemberMemberMonitorStatus memberState : memberStates) {
                     return memberState.getMonitor_status();
         return null;
The issue in what I am doing is that when you set the status of either monitor or session you use the CommonEnabledState object and I want to make sure that neither the session or Monitor are already set to the supplied CommonEnabledState value.
      * Set the Monitor State of a member to a given {@link CommonEnabledState}.
      * @param member
      *            - Member to set the session state on.
      * @param state
      *            - The {@link CommonEnabledState} to us.
      * @return {@link LocalLBMonitorStatus} of the member after it has been set.
      * @throws Exception
     public static LocalLBMonitorStatus setPoolMemberMonitorState(BigIPPool.PoolMember member, CommonEnabledState state) throws RemoteException, Exception {
         LocalLBPoolMemberMemberMonitorState newMonitorState = new LocalLBPoolMemberMemberMonitorState();
         newMonitorState.setMonitor_state(state);
         newMonitorState.setMember(member.getPortDefinition());
         LocalLBPoolMemberMemberMonitorState newMonitorStateArray[][] = { { newMonitorState } };
         lbpool.set_monitor_state(poolname, newMonitorStateArray);
         return getPoolMemberMonitorState(member);
      * Set the state of a member to a given {@link CommonEnabledState}.
      * @param member
      * @param state
      * @return {@link CommonEnabledState} of the member after it has been set.
      * @throws Exception
     public static CommonEnabledState setPoolMemberSessionState(BigIPPool.PoolMember member, CommonEnabledState state) throws RemoteException, Exception {
         LocalLBPoolMemberMemberSessionState newSessionState = new LocalLBPoolMemberMemberSessionState();
         newSessionState.setSession_state(state);
         newSessionState.setMember(member.getPortDefinition());
         iControl.LocalLBPoolMemberMemberSessionState monitorstatArray[][] = { { newSessionState } };
         lbpool.set_session_enabled_state(poolname, monitorstatArray);
         return getPoolMemberSessionState(member);
