FTP issue with requests being denied
My customer contacted me saying that they were having FTP connections rejected when in actuallity they should have been being load balanced over 5 servers. We were running a fairly large report (~19,000 print jobs) and it started rejecting most of the ftp connection that were attempting to send the jobs over for processing.
I am not seeing any errors in the ltm logs but am looking for advice on what to check or how to turn up some logging on this WIP/VIP/pool/nodes thru the F5?
- Michael_Yates
Hi Shane,
You should be able to use an iRule to gather some information. I would suggest going here:
Specifically look at the "IP" Events. I think these events will give you the information you are looking for.
CLIENT_ACCEPTED, CLIENT_CLOSED, SERVER_CONNECTED, SERVER_CLOSED
Hope this helps.
- nitass
Employee
if reject means tcp reset and you are running 10.2.3 or later, you may try to log tcp reset cause.
sol13223: Configuring the BIG-IP system to log TCP RST packets
http://support.f5.com/kb/en-us/solutions/public/13000/200/sol13223.html
and of course tcpdump can be useful in cases like this: http://support.f5.com/kb/en-us/solutions/public/0000/400/sol411.html
