Steve_A_129440's avatar
Steve_A_129440
Jul 16, 2013
Frequent SQL-INJ false positives
I am having a frequent issue of the SQL-INJ signatures matching and alarming on content that has no resemblance of a SQL injection attack.
Here is an example:
txtBio=
Julie0x20Brown:0x20Julie0x20‘
This flagged attack signature 200002175 - SQL-INJ create table.
Every day I get a couple thousand of these sort of false positives. If I disable on parameter then eventually I will have no paramaters being protected.
Any thoughts?
  • Steve,
    So that signature is fairly broad in its net cast (generic sql catch). I usually disable the generic one and leave all the more advanced mysql rules to provide protection.
    I'll need to look at the regex of the rule again, but if I recall it's called in the rule that it may have a higher false positive rate.
    Sorry for the brief response, in middle of a class.
    -josh
    security monkey
  • Thanks for responding.
    Have you found a way to look into the reg-ex that makes up that rule? I'd love to see the 'source' of some of these rules.
  • If anyone has a way to look at the source of Attack Signatures I would be grateful on how to do that as well.
  • nathe's avatar
    nathe
    \\+|\\/\\*)/Psi\";
    Josh did a tech tip on how to dissect attack sigs by creating a custom one which is a useful addition to this.
    Hope this helps,
    N
  • nathe's avatar
    nathe
    I ran asmqkview on an 11.x box and the asm_mysql.dump file isn't there :-(
    I will continue the search....
