Robert_Aarons_7's avatar
Robert_Aarons_7
Sep 20, 2011
Force radius requests from management interface
Running LTM 10.2.1, attempting to set up login authentication to a Radius server. I want the Radius server, which is on 10.240.5.20, to receive the requests from the management interface, however it seems to be fairly random whether the requests are sourced from this or the F5-INTERNAL-DMZ interface. (In fact, I don't mind which interface the requests are sourced from, as long as it is consistent).
The LTM doesn't seem to respect the route to 10.0.0.0/8 from its F5-INTERNAL-DMZ interface. What do I need to do to get some consistency?
The interface addresses and route table are below. Any help gratefully received.
[root@CLFR1_FR3-LBA:Active] config ifconfig -a
F5-EXTERNAL-DMZ Link encap:Ethernet HWaddr 00:01:D7:DC:5F:43
inet addr:172.16.205.3 Bcast:172.16.205.255 Mask:255.255.255.0
F5-FAILOVER Link encap:Ethernet HWaddr 00:01:D7:DC:5F:45
inet addr:172.16.207.3 Bcast:172.16.207.255 Mask:255.255.255.0
F5-INTERNAL-DMZ Link encap:Ethernet HWaddr 00:01:D7:DC:5F:44
inet addr:172.16.206.3 Bcast:172.16.206.255 Mask:255.255.255.0
eth0:mgmt Link encap:Ethernet HWaddr 00:01:D7:DC:5F:41
inet addr:10.240.6.11 Bcast:10.240.6.255 Mask:255.255.255.0
[root@CLFR1_FR3-LBA:Active] config netstat -rn
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
127.1.1.0 0.0.0.0 255.255.255.0 U 0 0 0 tmm0
192.35.172.0 172.16.206.1 255.255.255.0 UG 0 0 0 F5-INTERNAL-DMZ
127.2.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0.1
172.16.205.0 0.0.0.0 255.255.255.0 U 0 0 0 F5-EXTERNAL-DMZ
172.16.206.0 0.0.0.0 255.255.255.0 U 0 0 0 F5-INTERNAL-DMZ
10.240.6.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
172.16.207.0 0.0.0.0 255.255.255.0 U 0 0 0 F5-FAILOVER
164.11.0.0 172.16.206.1 255.255.0.0 UG 0 0 0 F5-INTERNAL-DMZ
192.168.0.0 172.16.206.1 255.255.0.0 UG 0 0 0 F5-INTERNAL-DMZ
172.16.0.0 172.16.206.1 255.240.0.0 UG 0 0 0 F5-INTERNAL-DMZ
10.0.0.0 172.16.206.1 255.0.0.0 UG 0 0 0 F5-INTERNAL-DMZ
0.0.0.0 172.16.205.1 0.0.0.0 UG 0 0 0 F5-EXTERNAL-DMZ
0.0.0.0 10.240.6.1 0.0.0.0 UG 0 0 0 eth0
  • you will need a b mgmt route statement to send triaffic to the radius server. for example:
    b mgmt route 10.240.5.20 netmask 255.255.255.255 gateway 10.240.6.1
  • Hi Rob
    I'm trying as well to authenticate users via radius.
    I use windows radius server and I'm not really familiar with radius.
    Could you help me please?
    Or what kind of radius server do you use?
    Best regards
    bb
