chris_connell_1's avatar
chris_connell_1
Dec 21, 2010
Floating self IP and virtual IP using same address.
Hi
A client is sending wap traffic to a virtual server (destination IP for the request is the virtual address defined on the F5 virtual server). This is not working in that I cannot see any replies from the virtual address or requests to the real servers. (Virtual/pool etc are UP) I found out that they are using the same IP address for the virtual address and the floating self ip, I am thinking this is causing conflicts, could this be the case?
  • hoolio's avatar
    hoolio
    Yes, it can work, but it's not generally a good idea as you're limited to which ports can be accessed as a self IP versus a virtual server IP. I'd look at the SNAT setting on the VS/routing if the pool is up, but no connections to the pool.
    SOL8849: Configuring a virtual server to use the same IP address as a self IP
    http://support.f5.com/kb/en-us/solutions/public/8000/800/sol8849.html
    It is possible to configure a virtual server destination IP address and a self IP to use the same IP address.
    Important: If you configure the BIG-IP web server and a virtual server to use the same self IP address, the virtual server will take precedence and process connections to the address.
    Aaron
  • Aaron - if you're doing an HTTPS VIP, you're no longer able to manage device via Self-IP:443 then? How about if you're doing SNAT Automap? Do replies to automap address hit VIP instead of self-ip?
    Thanks I removed the selfip as I dont think its a good idea generally.
    As a side note I want to test the connection to my virtual server works on the active device from the standby device by sending a telnet 8080. I can ping the virtual IP from the other standby F5.. (it has routing domain configured and is in routing domain %4)
    ping 10.252.1.61%4 <-- virtual ip on F5 active device
    PING 10.252.1.61%4(10.252.1.61%4) 56 data bytes
    64 bytes from 10.252.1.61%4: icmp_seq=0 ttl=64 time=4.15 ms
    But cant figure out how to connect to it from the standby device e.g. telnet 10.252.1.61 8080 via route domain4, I cant use 10.252.1.61%4, it gives me unresolved. I want to somehow send a request to it via route domain4 to check I get a response from port 8080. Any ideas? or perhaps I have to enter route domain 4 mode or something?
  • hoolio's avatar
    hoolio
    Hi Chris,
    It gets a bit "user-unfriendly" when trying to use CLI tools to connect to a virtual server in a non-default route domain. See SOL10467 for details on the issues:
    sol10467: Userland applications on a BIG-IP system cannot connect to hosts in non-default route domains
    http://support.f5.com/kb/en-us/solutions/public/10000/400/sol10467.html
    Also, I think it would be simpler to test from the active unit as there have been issues connecting from the standby unit to the active.
    Aaron
    I thought I was the only one who had these issues! Ill check that article thanks.
  • By chance, did you try netcat? You may find that curl, wget or netcat will honor the route domain syntax - I'm not sure though.
    -Matt
  • hoolio's avatar
    hoolio
    You basically need utilities that support IPv6 to connect from the LTM CLI to non-default route domains. So curl and netcat on LTM will work. But wget isn't included by default.
    I expect if you define a VS on 443 on an IP defined as a self IP, you won't be able to connect to the admin GUI on that IP. If you enable SNAT using that self IP, TMM shouldn't use any reserved ports (<1024) to source traffic from. The TMM connection table should handle packets for established connections so there shouldn't be an issue there.
    Aaron
