bilsch_10068's avatar
bilsch_10068
Oct 26, 2010
Fix to http persistence cookie logger irule
Was working with the persistence cookie logger irule, its logging the wrong value for ports.
http://devcentral.f5.com/wiki/default.aspx/iRules/Persistence_Cookie_Logger.html
Original code
set myPortD [string trimleft [expr 0x[substr $myPortH 2 2]][expr 0x[substr $myPortH 0 2]] 0]
Should be
    set myPortD [string trimleft [expr 0x[substr $myPortH 2 2][substr $myPortH 0 2]] 0]
Per the docs https://support.f5.com/kb/en-us/solutions/public/6000/900/sol6917.html , the 2-byte hex values are reversed, so should be re-ordered. However the value should be a single string, not 2 unique hex values.
( not sure if this is the best/right way to post this 😆 )
  • hoolio's avatar
    hoolio
    Hi Bilsch,
    Thanks for finding, fixing and pointing this out. Your interpretation looks correct to me:
    when RULE_INIT {
     From http://support.f5.com/kb/en-us/solutions/public/6000/900/sol6917.html
     For example, if the port of the destination server is 8080, the BIG-IP LTM encodes the port as follows:
     8080 = 0x1F90
     Reverse byte order = 0x901F
     0x901F = 36895
    set myPortE 36895
    set myPortH [format %x $myPortE]
    log local0. "\$myPortE: $myPortE, \$myPortH, $myPortH"
     Old, wrong way
    log local0. "Old: [expr 0x[substr $myPortH 2 2]][expr 0x[substr $myPortH 0 2]]"
     Updated, correct way
    log local0. "New: [expr 0x[substr $myPortH 2 2][substr $myPortH 0 2]]"
     Log output:
     : $myPortE: 36895, $myPortH, 901f
     : Old: 31144
     : New: 8080
    Aaron
